Do the new Nedap neck tag work with the eartags?
Hi! It depends, the Nedap neck tag uses the same technology as the eartag does. This is why these signals interfere with each other. If you want to use the Nedap monitoring than Nedap tags without identification need to be used. Hope this helps
