Hello
How do you replace the foam pads on The Collectors??
Is there a video or any other tutorial out there??
Thank you and have a great weekend!!!!!!!
Cheers, Marcel
Hello
Cheers, Marcel
Just to make sure I can point you in the right direction: do you mean the small foam rings or filters on the ultrasonic sensors, or another foam part on the Collector? If you could share a photo, that would help a lot!
Thanks Jam, that's fair comment. I should have been more specific. I'm talking about the foam rings around the ultrasonic sensors.
Thanks for your help!!!!!
Hi Marcel, I checked the Collector operator manual (you can download it at lely.com under Services, then Technical documents, filter "Collector C2"). It explains how to clean and test the ultrasonic sensors, but not how to replace the foam rings. That seems to be a job for your Lely Center, so the best step is to ask them. They can order the right rings for your C1 or C2 and swap them on their next visit.
