Hello,
Have a cow that gets randomly routed for the last 2 days but not on 'routing' in Horizon.
Need some help to sort this issue out pleased.
Thank you.
Hello,
Thank you.
Hi Marcel, sorry this is happening to you, it's very annoying issue. I've had this happen before. The first thing I'd check is whether the cow has any active attention, treatment, or selection criteria that could be triggering the routing. Also have a look at the routing history in Horizon to see which rule is actually sending her. That usually points you in the right direction.
