I want to be able to look at a quick list of cows A1/A2 genotype. Is there somewhere like on the cow card, additional information where it has cow blood percentage, hair colour etc, where this could be put?
that's a great question! I would like to know this too
Hey,
Unfortunately this is not possible at the moment. The only thing that you could do is add that to the cow note widget. So when you are at a cow card, you should see a widget with the name notes. If that is not the case you can add that by clicking on add widget and under widget type select 'notes'. In this widget you can type any note of a cow you want like the for example genotype.
nice answer. thank you
Thank you. I haven't really used the notes option before. When making a new report, will there be an option for the notes section to appear on a report?
You can only see this in the cowcard. It is not possible to add this to a report
